tts cable question
Old May 9, 2010 | 09:51 AM
powerlab's Avatar
powerlab
Default tts cable question
Hey all...i screwed up the black cable going from my interface to the bike...There are 2 cables listed...one for 34.99 and one for 78.99.The one going to the comp is a usb to serial.I just dont know which one i need to buy...Again i need the one that plugs into the bike just dont know if its the cheaper one or expensive one.When i got my tts i ordered both cables from them....thanks for any info
Old May 9, 2010 | 09:05 PM
ColdCase's Avatar
ColdCase
The cable depends on what your laptop has. Some have serial most have USB. They usually have USB and most get that cable. The USB end plugs into the computer, the other end to the TTS module.
Old May 10, 2010 | 09:44 PM
powerlab's Avatar
powerlab
Default cables
Hey cold case..thanks for the reply...i understand the cables and have the usb cable....what my problem is is that i need the cable that goes from the tts interface to the bike...and theres 2 cables listed to buy..one for 34.99 and 1 for 78.99.Does the cable i need also come in these cable kits?One is a serial and the other is the usb but i need the one that goes to the bike...thanks for the reply....kevin
Old May 11, 2010 | 04:43 PM
ColdCase's Avatar
ColdCase
I thought that cable comes with the module. The two choices you mention are for serial interface to the Computer or USB choice. If the Module-ECU cable didn't come with the module, it comes in both of the cable kits. I'd call Mastertune to double check.
Old May 11, 2010 | 05:00 PM
powerlab's Avatar
powerlab
Default cables
got ya...thanks for the info colecase...
harley7316
Oct 18, 2013 11:12 AM
BlockHead96
23
Jul 15, 2010 08:51 AM
cafedante
Exhaust System Topics
Jun 28, 2010 03:55 PM
Bobbed Out
Jan 29, 2010 05:58 AM
OneBlackFly
General Topics/Tech Tips
Jul 7, 2008 03:48 PM
