SE Ignition problem
Old Jun 5, 2010 | 01:54 PM
stewart1962's Avatar
stewart1962
Default SE Ignition problem
Hi folks, looking for a little help here.
Before this 1999 bike was striped down over the winter, it had an SE ingnition installed and ran perfect.
The engine has been put into the frame and wired for the ignition side only to see if were getting a spark, when i hit the button the plugs only spark once, the wiring has been checked by 4 differant people who have built these bike before and all agree its wired correctly. So we thought the ignition module was goosed, so i bought a new one and fitted it and it still only sparks once.
I am getting conflicting stroies about these units, some pepole say, just plug it in and it should work, others say it needs programing, but no one can tell me how to do this.
I have been told if i get a standard harley ignition unit and plug it in it will work.
The new unit is Ł251.00 plus VAT.
So my question is, has any one had this problem before and managed to get it sorted?
And before i buy a standard harley 1, is there any other makes out there which are cheaper, and just, plug in and go.
Many Thanks
Stewart
Old Jun 5, 2010 | 08:19 PM
RA51's Avatar
RA51
The SE module you have in the pic is plug an play only. You install it, set timing an that is it. Nothing to program. I have one of those modules I use to run on a 2002 sportster I had.
Old Jun 6, 2010 | 02:41 AM
stewart1962
many thanks
I will need to have anothet look at the wiring.
Old Jun 6, 2010 | 05:50 AM
Lonewolf176's Avatar
Lonewolf176
Do you have a set of plugs in the heads?
Old Jun 6, 2010 | 10:40 AM
stewart1962
spark plugs are in the leads and im touching them to earth to see if they spark
Old Jun 6, 2010 | 10:50 AM
Lonewolf176
Put some old spark plugs in the heads and then check. I not sure about yours but on the newer bikes the ecm needs to sense compression or it will not fire the plugs more than once.
Old Jun 6, 2010 | 01:05 PM
stewart1962
Problem solved
Thanks very much for your help.
I put in a standered back plate with an external ignition module and the bike is sparking fine.
The new SE ignition module i got from harley is obviously Knackered, so i will be returnig as soon as.
Many thanks
Stewart
Ultra9617
Evo Era Parts
Jan 24, 2019 05:11 AM
Delii Mon'Delii
Dec 24, 2016 11:31 AM
stewart1962
Jun 7, 2010 09:28 AM
tkb540
Dec 29, 2008 08:01 PM
HaggisMan14
Jun 15, 2006 05:51 PM
