Help! Spark plug wire resistance, bag ignition module?!
Old Dec 24, 2016 | 04:00 AM
Delii Mon'Delii's Avatar
Delii Mon'Delii
5th Gear
Default Help! Spark plug wire resistance numbers, bad ignition module?!
98xl1200c 60k
I'd like to check the plugs wires to make sure that they are good. I have 2 year old SE wires. Bike is a daily rider. Starts fine stone cold, but heated it won't restart backfires crazy with added throttle making it miss and backfire. Changed the coil, plugs. Same same. Ran it then quick cooled the ignition module with a bag of ice on the nose cone, started right up. But I wanna test the ohms resistance on the plug wires themselves.
Disconnected what should be the resistance numbers??
years ago I spend $$ for nothing only to have a problem with the wires.
Or or is it for sure the module which is $200+
​​​​​​​going through chemo so help a brotha out
Old Dec 24, 2016 | 08:31 AM
72 Ironhead XLH's Avatar
72 Ironhead XLH
fuel restriction,carb problem?
Old Dec 24, 2016 | 09:21 AM
cHarley's Avatar
cHarley
Originally Posted by Delii Mon'Delii
98xl1200c 60k
Common problem on older EVOs with the nose cone ignition modules and it's not only telling you it's failing, you've proved it. Regardless of other tests you want to do, it's time to replace the ignition module.
Old Dec 24, 2016 | 10:22 AM
Delii Mon'Delii
5th Gear
Default Fuel is clean
Yes, I still wanted to find the spark plug resistance numbers.
As as for the fuel system it's totally overhauled clean wise.
​​​​​​​part is on order!
Old Dec 24, 2016 | 11:31 AM
JustOneDean's Avatar
JustOneDean
Per the '98 Sportster manual: 1,625-3,796 ohms for 6-1/2-in. cable, 5,000-11,680 ohms for 20-in. cable.
I don't know if the SE cables should have different resistance values.
AKFXD
Apr 7, 2016 07:07 AM
Shackleford
Aug 21, 2014 08:51 PM
FXD_noob
Nov 14, 2013 01:32 PM
av8or
Jul 6, 2010 10:40 PM
daholken
Mar 28, 2009 09:46 PM
