Lowering idle speed on FI bike.
Old Jun 30, 2010 | 09:49 PM
rjohn61987's Avatar
rjohn61987
not sure what you mean. just sayin'. read this thread from the start and I am learning a lot. pls be more specific. I am old and don't understand a lot of the acronyms.
Old Nov 5, 2010 | 11:44 AM
Dick Long's Avatar
Dick Long
3rd Gear
im a 25 year harley certified tech so here is the deal on the idle of f.i. bikes. its easy to set the idle on a m.m. f.i. bike just a torx screw, but the delfi are different, you can use a scanaylzer and set the idle but the ecm has a chip to set the idle back to factory setting so it want do ya any good. this is for safety reasons (per h-d) all late bikes are electronics so when the voltage drops to low due to low charging at low rpm the bike can quit and you might get run over at a red lite when it changes, also the oil issue is no problem, these roller bearing motors work mostly off of splash oiling they can run over 800 miles with 1 pound of pressure (normal riding) befour causing any problems. i have seen this proven twice. everyone will tell you the hydralics will colaspe they might but they didnt in the ones ive seen, and all they will do is make some noise and not run as well. hydralics can operate off 3psi. the idiot lite operates off 5psi +/- 2psi. if you want to lower the idle get a thunder max ignition, if you want potato, potato, you need about 8.5 compression with hemi heads/domed pistons. they are alot of opions, hope this helps.
Old Nov 5, 2010 | 06:58 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Fascinating. A 25 year harley certified tech doesn't know that I can set my idle to 800 RPM with my SESTP? My tach verifys that I am indeed idling at 800
I have a question of the 25 year harley certified tech. How long does the bike have to idle to get this "voltage drops to low due to low charging at low rpm"? This probably isn't a poblem for me since I don't idling any longer than I actually have to. Guess I could test this by putting a voltmeter on my bike while it is idling at 800 rpm.
Old Nov 5, 2010 | 11:19 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I can change my idle with my SERT as well. But I won't because of the oiling/charging issue.
Old Nov 6, 2010 | 03:05 AM
msocko3's Avatar
msocko3
+1 I can change mine also, but why try to put lipstick on a hog. To me a TC struggling to idle just sounds like a poorly tuned TC, doesn't sound cool just sounds like it needs worked on.
Old Nov 8, 2010 | 05:33 AM
jluvs2ride's Avatar
jluvs2ride
I just think this is a non issue.
Old Nov 8, 2010 | 05:39 AM
jluvs2ride's Avatar
jluvs2ride
Well, everthing on the bike is perfectly adequate as it rolls off the showroom floor. However we change lots of things to express what we like.
I just like the 800 rpm idle better than 1k. 200 rpm diference, it certainly doesn't sound like it is struggling or poorly tuned.
I will put a volt meter on my battery at idle and report back on the voltage.
Old Nov 8, 2010 | 07:18 AM
harleytuner's Avatar
harleytuner
I've seen oil pressure as low as 5 Lbs. at 1000 RPM's, i've seen them down to 3 Lbs. at 800 RPM's, this is verified with an oil pressure gauge threaded into the oil senor unit port on the block, not the junk gauge that comes stock on touring bikes. (Don't trust that gauge, it's about as reliable as the fuel or air temp gauge). I personally wouldn't want my RPM's lowered under the 950 to 1050 idle that Harley wants it at. I figure thier engineers probably know a little more about it than I do so why mess with it.
Old Nov 8, 2010 | 07:34 AM
peppi's Avatar
peppi
Things to be considered with a lower idle speed is not only the oil pressure but the alternator output with the extra load on a FI bike like the fuel pump and some other parts that would take more output to run properly than with a carbed bike.
Old Nov 8, 2010 | 11:24 AM
harleytuner
I'm not sure that would be effected so much. There are a ton of people out there with all kinds of lights, stereos, etc. that eat up alot more juice than turning down the idle. I see some bikes that look like spaceships riding down the road with all the lights
