Lowering idle speed on FI bike.
Old Mar 24, 2012 | 11:51 AM
  #71
hacksawsgarage's Avatar
hacksawsgarage
Originally Posted by jluvs2ride
Well, everthing on the bike is perfectly adequate as it rolls off the showroom floor. However we change lots of things to express what we like.
I just like the 800 rpm idle better than 1k. 200 rpm diference, it certainly doesn't sound like it is struggling or poorly tuned.
I will put a volt meter on my battery at idle and report back on the voltage.
good man! hold your ground!
these guys go out and buy hogs, then complain some one wants to put lipstick on a pig? LOL!
that high idle suks.
Old Nov 12, 2012 | 10:07 AM
  #72
LURCH2013's Avatar
LURCH2013
Stage I
Default Idle
I'm sure it will slow your oil feed but I also know it will slow your charging system.....in turn also provide less power to your fuel injection system at low RPM. I was looking to do the same on my 06 Fatboy but i am going to change cams, etc
Old Nov 12, 2012 | 03:36 PM
  #73
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
I verified that voltage was not a problem by using my SEPST and doing a data run and later comparing voltage at idle to voltage at 2.5k rpm. Minimal difference. Oil pressure is more likely where you'll see the difference but everything I know of so far has been anecdotal.
Old Apr 12, 2016 | 03:46 AM
  #74
FatBoy1962's Avatar
FatBoy1962
1st Gear
Hi,
I am new at this forum. It is easy to lower the idle speed if you have a supertuner (800rpm), but my question is, why is it even possible to lower it if you can damage your engine? can someone answer please?
Old Apr 12, 2016 | 06:38 AM
  #75
FatBoy1962's Avatar
FatBoy1962
1st Gear
Default Idle speed twincam
Hi,
Old Apr 12, 2016 | 07:58 AM
  #76
MURPHCC1's Avatar
MURPHCC1
Ya know this thread is like 3 1/2 years old right?
Old Apr 16, 2016 | 02:33 PM
  #77
Softail65's Avatar
Softail65
I bought this item 2 Years ago, I like it, my wife in his sportster too.
http://www.american-motors-usa.com/t...tail-2006-2016
I have the full control over the Idle speed , anytime!
Fits all EFI without TBW
Softail65
Harley Davidson Videos
May 5, 2019 03:24 PM
radudel
Feb 28, 2012 04:38 PM
editbrain
Dec 21, 2010 08:48 PM
LowBoy08
14
Sep 2, 2009 08:27 PM
dog155
Jan 24, 2007 02:08 PM
