running problems
Old Jun 20, 2010 | 04:14 PM
hoppynwv's Avatar
hoppynwv
4th Gear
Default running problems
I took a 99 sportster 1200 put it on a poco rigid frame. Eliminated all the wiring except the basics. Runs good until you put it in gear then it quits. Can anyone help or know why it does this?
Old Jun 21, 2010 | 11:03 AM
Old Gunny's Avatar
Old Gunny
So in neutral till put into gear? Is there a indicator light?
If it runs OK till put into gear sounds like a interlock is in the sceem of things maybe.
Old Jun 21, 2010 | 08:03 PM
hoppynwv's Avatar
hoppynwv
4th Gear
No there isn't an indicator light.
Old Jun 24, 2010 | 07:51 AM
hoppynwv's Avatar
hoppynwv
4th Gear
there is no indiactor light....
Old Jun 24, 2010 | 06:50 PM
Old Gunny's Avatar
Old Gunny
Kind of thing I meant was, why would it run till you put in in gear?
Just stops or dies when giving it the gas?
Its like there is something, at the first question, killing it. Oil pressure ?? Something like that.
Voltage problem?
Gotta be something, unless there is magic involved, that'll cause problems for sure. Seen that happen in Louisiana.
soft 02
Aug 6, 2013 01:31 PM
kyle90
Jun 8, 2012 06:37 AM
soft 02
Dec 16, 2010 07:59 PM
stevieg
Feb 22, 2008 11:23 PM
badlands
Jul 15, 2007 11:55 AM
