PCV question
Old Sep 17, 2010 | 10:17 PM
Black Train's Avatar
Black Train
Default PCV question
Guys I have searched and have not been able to find the answer so here goes. I got a PCV for my 07 Train. The maps for my 07 Train are for the PCIII. Can I use a map for a 09 Train off of Power Commanders web site? Will this work for my bike or am I SOL? Got the PCV hooked up and now need to throw a map on it.
If it makes any difference I have V&H Short Shots and SE Heavy Breather with Stock ECM.
Thanks in advance. Might should have got with Fuel Moto! My bad.
Old Sep 18, 2010 | 07:41 AM
nvsteve's Avatar
nvsteve
I think the PCV has an extra throttle position column so I would think it wouldn't be correct.
Try comparing any PC111 map to a PCV and take a look.
Old Sep 18, 2010 | 10:45 PM
OIF08Streetglide's Avatar
OIF08Streetglide
Default Pcv
I have been using the PCIII for over a year now. My bike is a DBW so the PCV was not compatable. The PCV web site claims for 09 and up so I'm not sure it will work at all, even if the connections are the same. After looking at the 09 maps M15-004-077 or M15-004-078 look close. My concern would be the sensor differences between the 2 model years among other things. I had very good results with the PCIII. The map I used didn't match my setup exactly (different cams) but it was close and worked like a charm, I made a few adjustments to smooth out the transition from 30-40% throttle but that was it, until I changed my baffles. Spent a lot of time tweeking to get the engine back to a happy tune. I have since changed to a different tuner. Hope this helps a little...
Old Sep 19, 2010 | 04:24 AM
Watch Guy's Avatar
Watch Guy
Default You need to call the folks at powercommander
The PCV has been retrofitted for the older bikes but evidently they haven't updated their website to show that. They will send you a map based on your config or you could just take it to a shop that has a dyno tech that actually knows what he or she is doing.
Old Sep 19, 2010 | 07:48 AM
nvsteve's Avatar
nvsteve
The PCV will work on older than 09 bikes. Several here are using it along with autotune.
Old Sep 19, 2010 | 07:36 PM
a34655's Avatar
a34655
When you open the PCV software, click on "file" on the top left corner them click on import PCIII map. From there find where your PCIII map is and open it.
Brick0044
Sep 30, 2012 12:27 PM
dohadex
Feb 21, 2011 06:46 AM
JackieGrier007
Mar 7, 2010 09:04 AM
LouEyez
Nov 19, 2009 06:06 AM
jeff.georgalas
13
Oct 17, 2009 09:19 PM
