Mytune question.
Old Sep 29, 2010 | 02:18 PM
ubreal's Avatar
ubreal
Default Mytune question.
With Mytune, Would I use logs that were made with the enable smart tune box check or would I use logs that I made with the box uncheck? I have the Mytune program but no instructions came with it.
Old Sep 29, 2010 | 09:51 PM
RA51's Avatar
RA51
With MyTune I would just make some data runs an save the log files an process them thru MyTune. MyTune works very well using the data in closed loop for ve an timing changes. I would not worry if I checked smart tune or not as you will be using MyTune to set tables.
Hilly13
The Dyno Room
May 7, 2017 01:36 AM
RCinLaveen
Apr 30, 2014 09:45 AM
berniemc
Exhaust System Topics
Jul 9, 2012 10:50 AM
pmcburne
May 21, 2010 01:29 PM
mang0
Apr 1, 2010 10:07 PM
