2007 TC96 ignition swap (EFI to carb)
Old Oct 12, 2010 | 10:58 PM
Stacyptaylor's Avatar
Stacyptaylor
Stage IV
Default 2007 TC96 ignition swap (EFI to carb)
Hello all. Can't find the answer to this question anywhere. I have a TC96 that I am using in another application. My question is that I'm removing the efi and moving to a carb. Will an aftermarket ignition work or is there anything special about the ignition that comes standard. I'm not worried about speedo, signals, etc. Just have the ignition question. Thanks
Old Oct 13, 2010 | 12:15 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Good question. Since the entire engine runs off of input signals from various sensors including those in the throttle,intake and EFI system you are going to have some real engineering to do with regard to the ECM programming. I have never heard of an aftermarket kit but maybe someone will chime in.
Old Oct 13, 2010 | 12:30 PM
Stacyptaylor
Stage IV
Default Just to clarify
Thanks for the reply. Just to clarify.... I'm stripping the motor of all electronics... Going to a basic carb setup and basic ignition. To be honest it's going to be used in a custom chopper. Nothing electrical, just the ignition. So I guess I'm wondering if I can use this motor. Thanks everyone!
Old Aug 22, 2012 | 11:02 AM
Altruism111's Avatar
Altruism111
Stage I
You will need a Ignition system from a company called Altmann by micro machines the ignition I'm ordering is a Amn-p3 it works off of the crank sensor of the bike.
Old May 7, 2013 | 08:33 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Thunder Heart make a Stand Alone Ignition System for the Twin Cam using the OEM crank trigger. Cost around $300. FYI ... they make the Thunder MAX EFI system Zipper's sells.
northshore_paul
Apr 15, 2018 01:29 PM
Road Star
Nov 27, 2013 10:09 AM
Road Star
Sep 14, 2013 09:21 PM
sealdoggy04
Exhaust System Topics
Dec 10, 2009 09:56 PM
feetsbig
Feb 24, 2007 01:23 PM
