Help with Thundermax tuner
Old Nov 4, 2010 | 04:01 PM
nevil's Avatar
nevil
You also should check that you have the latest firmware, just to be sure.
Old Nov 11, 2010 | 09:18 AM
bigdan65's Avatar
bigdan65
picked bike up from dealership yesterday. All they found were the plugs and wires. Had some Stainless wires on there that were bad. They suggested I change my heavy breather, said it was flowing to much air for the Thundermax. I just cleaned it and think I may have not oiled it enough. I reoiled it when i got home.
Old Nov 12, 2010 | 08:11 AM
Scottla's Avatar
Scottla
6th Gear
I read eleft's reply, was wondering if theres anyway to avoid destroying your sensors with assembly fluid?, I'm doin a 103BB also, just curious.
Old Nov 13, 2010 | 07:30 AM
eleft's Avatar
eleft
If I knew I would have removed the o2's and plugged the bungs when I did the heat cycle run in.
I think it would have burned the fluid off instead of messing them up.
Al
Old Nov 15, 2010 | 09:29 AM
bigdan65's Avatar
bigdan65
Went for a ride Sat, bike ran good, ran better the longer i rode. It started out kinda iffy but after it warmed up i am pleased.
Old Nov 16, 2010 | 09:46 AM
SURFOR Chop's Avatar
SURFOR Chop
That's the goofiest **** I've ever heard ... this proves the guy knows absolutely nothing about ThunderMax ...!
TMAT uses wideband sensors that continually sense the amount of O2 in the exhaust ... and adjust the fuel to attain the desired AFR (as per the programmed map) ....
If the A/C was flowing 'too much' air ... the TMAT would notice (in a nano-second) and add fuel to maintain the correct ratio ....
Sounds like whatever your issue was might have been related to your plugs or plug wires ...
bigdan65 ... I strongly recommend reading the technical pub for the TMAT and bone up on it by reading a few threads on the forum on the subject ... there is an excellent education to be had ....
But, the beauty of the system is that once its up and running it is almost 100% trouble free--fire and forget! (... except for bad battery cable connections, fouled O2 sensors or other miscellaneous 'gremlins' ...!)
On the subject of not ruining the O2 sensors ... if you remove them from your pipes during your break-in ... do you take the bike off of 'closed loop' (that is, check the box in the setup for 'open loop') ...?
I suppose you could just select the base map for your particular setup and run that as 'open loop' operation until the assembly fluid has burned off ... then, reinstall the O2 sensors and re-set to 'closed loop' operation ....
R/
'Chop
Old Jan 3, 2011 | 04:41 PM
bigdan65's Avatar
bigdan65
more problems!!! Took the bike to Charleston where is was gonna be warm, so we could ride on New Years Day. BIKE RAN WORSE than ever. Gonna take it back to one more time to see if O2 sensors need changed out. I have 1 year left on warranty so I want them to have to pay for it.
i am not taking the heavy breather off, it ran great when i bought the bike for 2500 miles so I know it works.
If anyone knows a good tuner, mechanic within reasonable driving distance I am ready to take it somewhere else.
Old Jan 4, 2011 | 07:15 AM
eleft's Avatar
eleft
Dan,
Sounds like the power got disconnected from the ECM and needs to be reinitialized.
You know the 30 seconds and 30 seconds off times 3
Al
Attached Thumbnails Help with Thundermax tuner-removing-changing-or-charging-the-battery.jpg   Help with Thundermax tuner-t-max-initialization.jpg
Old Jan 4, 2011 | 07:48 AM
bigdan65's Avatar
bigdan65
thanks, i will give it a try.
Old Jan 4, 2011 | 11:04 AM
donovann2o's Avatar
donovann2o
unless power was completely disconnected or interrupted to your ecm you dont need to recalibrate the tuner with the 30 sec intervals. Stick with the original plan and replace the sensors...or find a tuner that can plug into your ecm and see what is really going on.
