08 SG ignition question
Old Feb 19, 2011 | 04:19 PM
08sgmissouri's Avatar
08sgmissouri
Stage III
Default 08 SG ignition question
Tore down my 08 SG for paint. When I removed the inner fairing I wound up moving the ignition off lock with the shaft not fully engaged. Got the alignment tool and re-aligned the switch so that it would go on fork lock. After putting everything back on, when I put in the Maxi fuse I get power to the gauges and cruise control. When I turn the switch to ignition the lights work and it starts and runs just fine. Why is it getting power to the gauges and radio when in the lock position? Have I got the ignition lined up wrong?
I have tried rotating the switch with the tool not fully engaged as the book suggest but no help. Any suggestions?
Old Feb 21, 2011 | 10:03 AM
08sgmissouri
Stage III
Default ignition switch
wound up being a bent pin on the alternator gauge. Thanks for the help.
dyna rider
2014-2024 Touring Models
Oct 30, 2016 11:21 AM
TVan
May 18, 2013 09:17 AM
Gliden
Jan 2, 2012 04:23 PM
eddy5664
Nov 14, 2008 02:29 PM
2006streetglide
Feb 6, 2006 07:06 PM
