Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Do we have any concerns with the number of times we re flash our computers with new tunes. Just wondering if any damage to the computer could happen.
Thanks
Im thinking of putting in bigger injectors and a 57mm throttle body on my 107. Can I just increase the injector size in the the map to match the new injectors and then tune with the wideband sensors. Or are there other parameters to consider changing before I start tuning?
Thanks...
The injector swap is easy to accommodate for, you will simply change this under Fuel/Injector size. When changing the throttle body however you will want to recalibrate the VE tables as this will affect engine airflow directly.
Thanks
I had a PC crash due to lightning and had to start all over again. The newly built PC has Windows 7 enterprise 64 bit on it and I will have to download the PV tuner software again for that version. My laptop is still XP Pro 32 bit. So my question is, if I work on my maps using the PC can I still move them to my laptop and work on them it too? I guess what I am asking is do the maps care which windows version is used to tweak them?
Yes you can switch between computers with your calibrations no problem
FYI, we have now introduced our Power Vision Value Bundle. With every Power Vision purchase Fuel Moto now includes our PV Value Bundle which features a FREE Fuel Moto articulating handlebar mount and FREE Dynojet Visor kit, this is a $44.00 value. This allows users to easily and quickly mount and remove their Power Vision when doing tuning runs or simply displaying data. As always when you purchase from Fuel Moto we will program the PV with a Fuel Moto calibration for your setup, we offer unlimited support, and your PV is guaranteed to be the latest unit with the newest firmware and updates.
For those of you looking for the FM handlebar mount, it is a very trick high quality mount that is pretty inexpensive at $24.99 and can be found on our website http://www.fuelmotousa.com/harley/fm-barmount.html
Here are a couple pics of the complete bundle as well as the PV with FM bar mount and visor as mounted.
i am only up to page 236 and i have the documentation provided by dj as well as a (not sure how recent) copy of the guide justdennis has posted.
realizing that there are many changes to the pv over the course of 360 pages and wanting to go for a ride, i have a quick question
with a map offered by dj can i just hit autotune and go like the dj documentation suggests or do i need to manually change/setup the map as suggested by justdennis before i start using autotune?
2011 blackline stock pipes no baffles with w258 thunder torque inserts and outlaw highflow intake from dkcustoms
(and yes i wish i had purchased the pv2 from fuelmoto)
realizing that there are many changes to the pv over the course of 360 posts and wanting to go for a ride, i have a quick question
If you update to the latest PV firmare and use the Auto Tune Basic mode on the unit you do not need to change/setup the calibration as the PV does this for you. Essentially you will go to Program Vehicle/Auto Tune/Enable AT/Select Narrow Band sensors and the PV will setup the tune for maximum closed loop learning and reflash. You can then start the bike, go to Program Vehicle/Auto Tune and select Datalog and it will bring up the green AutoLogger screen which will show live data. Anytime you have this screen up it is collecting data which can then be applied directly to your calibration from the Auto Tune screen under Export Learned values. Works very slick...
