Power Vision Information Thread
Not to panic anyone, but I've had trouble with this arrangement and DJ is working to figure out why. When the splitter is used the gauges blank sporadically and the PV will lock-up. Unplug the AT-100 and all is well again. The data port only provides power for the AT-100, so in theory if you attach 12V to pin 4 and ground to pin 2 the unit should work. After powering mine in this way it still doesn't work, so I obviously haven't delved into any datalogging with the AT-100 yet.
I haven't used my AT-100 yet with the power vision, so I will just wait until you get the bugs worked out.
thanks for posting. I already have the cables from Jamie but wanted to try with the stock O2 sensors until I got the hang of it. Sounds like it was the right thing to wait.
thansk for posting I already have the cables from Jamie but wanted to try with the stock O2 sensors until I got the hang of it. Sounds like it was the right thing to wait.Also, has anyone been running the AT-100 with splitter and CAN cable to the PV with success? If so, please state year-model and any details you can.
I just backed up each stock backup to my computer and restored them to the Power vision one at a time to see if I could get it that way. No, it still shows the original ECM load. We have a bug here somewhere.
My rig is as follows...2011 Dyna Super Glide Custom... PV with a newly purchased AT Pro kit...contains an AT module, CAN cable, two WB O2 sensors, and the splitter cable. Like I said, now that I have the bugs worked out, it seems to be working perfectly.
The only issues (beside the one stated) had to do with the instructions (or rather, the lack of instructions) with the AT kit... None are included, and the only written info that's included refers you to the PCV documentation on DJ's website... however, the AT module I have is different than what's shown on those directions... I have a single module with two sets of connections (one for each 02 sensor), whereas the website shows only a single set each on a pair of AT modules... But hooking it up still was easy enough. I only had to verify that the connections labeled "1" corresponded to the front cylinder.. nothing, anywhere, says that. Jamie cleared that up in an email.
Art
band sensors seem to show up for tuning changes. Warm up lamda always seems to read 00.0. Most odd.
Have the day off Thur and will spend more time on this.
To setup the map for wideband tuning, I have set all of the AFR values in the cruise range to 13.8, Disabled Accel Enrichment and Decel Enleanment, Disabled PE mode & EITMS. Is there anything else you guys are setting for wideband tuning?
The values of the VE table represent the volume of air moved by the engine... measured as a percentage of the engine's displacement...right? So, without any type of forced-air induction system (turbo, supercharger, RAM-air, etc.), how can those values be above 100%?
I realize that the values can be manipulated manually! But, as we use the logtuner and our 02 sensors to tune our engine, we're actually calibrating the VE tables for our specific engine...so even if we started with a map that had a bunch of values above 100%, wouldn't all these values decrease to some number less than that? On my engine, there are areas of the VE tables, especially for the rear cylinder, where the values are over 100, and aren't changing much.
These are areas where data IS being gathered... I obviously wouldn't expect changes in areas of the table where no data hits are recorded. And, the displacement of my engine is listed correctly in the Engine Displacement table.
It's not that I think something's wrong...I'm just trying to puzzle out the whole process so I understand it better.
Thanks,
Art
