Power Vision Information Thread
Old Jun 2, 2011 | 07:04 PM
  #531
JustDennis's Avatar
JustDennis
Originally Posted by iclick
Steve is going to hype his product and does, but I still don't see how you can tune beyond the closed-loop area when there is no feedback (sampling). It just seems like smoke and mirrors, and any efforts along those lines would appear to be guesswork. There's nothing wrong with that as long as it is represented as such, not as a way to get a truly accurate tune. With the AT-100 Basic, using the same stock sensors, it is represented as a way to tune 2/3 of the range, which is realistic, and at least the PV has the Pro version that can sample throughout the operating range. Just my 2˘.
iclick
Have you run tuning logs with both the Autotune wideband sensors and the stock O2 sensors? The Vision tuning manual leads me to believe the narrow band stock O2 sensors tune at idle and low load and the wideband at higher loads.... quoting
"*Special Feature*
Log Tuner Pro can also use the factory narrow band sensors to create the corrections needed to properly calibrate your ECM at idle and light load ranges; then utilizes the Dynojet Auto Tune module that uses wide band oxygen sensors to tune for best power and torque. Since Auto Tune Pro can use data that’s natively on board and Dynojet wideband technology you get the best of both features."
I was wondering if you should tune with one the the other?
Old Jun 2, 2011 | 07:23 PM
  #532
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by FX4
A question or two about closed loop Bias values.
Jamie, you are currently setting the bias in closed loop to 700mv. The works out to an AFR of: 14.63 assuming 14.6 on the AFR map is really 14.68. On another map I have (TC96) you have the the bias voltage set to 778 which works out to 14.45, assuming the AFR 14.6 is really 14.68. So my question is can I increase the bias voltage a bit more to get the running temperature down some. Currently sitting in traffic, stop and go I'm building a lot of heat fairly quick. With an out side air temp of about 72F, five minutes at a stop light yielded an engine temp of 302. I'm thinking on a hot day this is going to be a bugger. Also my running temp down the Interstate is running between 260 and 280F.
The bias tables in most OE calibrations are in the 400-550 range however we generally like to see them in the 700-780 range. Increasing the closed loop bias values will richen the mixture by setting the voltage the ECM looks for as it toggles from rich/lean as the O2 integrator rolls. On Lambda based calibrations you control this directly
Here is a chart that may help
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jun 2, 2011 | 07:31 PM
  #533
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by JustDennis
iclick
"*Special Feature*
Dynojets statments simply reflect the systems ability to tune much of the calibration without purchasing any additional equipment, however the Auto Tune module certainly works awesome for the higher load/upper RPM areas you cannot get to using the factory nbO2 sensors. You can use both sensors to create your tune, however when using Log Tuner Pro with the AT module I recommend setting up the calibration in open loop to avoid tuning around a "moving target'. I would change the cruise range in the AFR table to 13.8 and the Auto Tune will tune the full VE table. Once you have your tune logged and corrected with the widebands I would reinstall the factory O2 sensors and go back to the original AFR table with the closed loop enabled. If you choose to do so you can leave the AT module installed and use the widebands and monitor your tune right on the PV display in real time
Old Jun 2, 2011 | 07:45 PM
  #534
FX4's Avatar
FX4
I set the 1000RPM range to 798 and I am finding the temperature sitting at light climbs much slower. I also found that moving the bias to 778 in the cruising range dropped my running temp down to right at 240F.
Old Jun 2, 2011 | 08:58 PM
  #535
Lonewolf176's Avatar
Lonewolf176
With the setting of 798 you will have to watch for sensor degradation. As the sensor wears the operating window becomes narrower. Another option is once your ve's are calibrated you can pull your idle area out of closed loop and run a little richer afr.
Old Jun 2, 2011 | 09:22 PM
  #536
FX4's Avatar
FX4
My understanding is up to 800 is safe for sensor degradation. The Vtune maxes out at 798. However I think you are correct, pulling idle out of closed loop is probably the best idea.
Old Jun 2, 2011 | 09:39 PM
  #537
etitanic's Avatar
etitanic
You do not need to reset the fuel trims as PV Log Tuner is using data that is already being used natively by the ECM to correct the VE tables during normal closed loop operation. When using this application you are essentially applying the corrections that the ECM has learned and stored, but rather than store them in the background as adaptive fuel values it is applying them directly to your VE table. This will allow the O2 integrator to roll more efficiently and since the system constantly switches from lean/rich it will deliver a more accurate mixture
Thanks Jamie,
I ran the tune a number of times and only during the first two runs had any adjustments and these were to spark advance table for the front cylinder. 3 more runs did not make any changes. I did start with the tune provided by Fuelmoto and have been pleased with the results so far. I will give the PV a better test as I am off on a 4000 km trip to South Dakota and back. Yahoo can't wait.
Old Jun 2, 2011 | 10:14 PM
  #538
Scotd's Avatar
Scotd
6th Gear
Default I think I am messing up
I keep running new log file and then doing the calculation and My VE tables keep getting smaller and smaller I am under the stock settings in allot of the rows. In fact I am down to a 66 at 1000 RPM and 35 KPA Stock was 74.
This is for the front Cyl.
It just don't seem right?
Old Jun 2, 2011 | 10:19 PM
  #539
FX4's Avatar
FX4
What do you think VE tables do? They just model how air flows through the engine. All you are looking for is no more changes. It took two runs on my bike and I'm nowhere near stock.
Old Jun 2, 2011 | 10:47 PM
  #540
Scotd's Avatar
Scotd
6th Gear
Well I thought with the SE/Air Cleaner and the S & S Power Duals. With the S & S SPO Mufflers that the Air flow would be more. I did 10 runs tonight and the just keep getting lower and lower. I just think it is strange that some fields are less than stock.
