Power Vision Information Thread
http://www.fuelmotousa.com/powervision.htm
Once you get the software running and have read jamie's instructions (3 post back) and the manual that should answer all your questions.
Using the stock narrow band O2 sensors.
How many times are you running the Log and then the PV Tuner Software? I have done it twice and really noticed improvement.
I am surprised how the VE tables look. It is not at all what I expected. I thought I would see a linear increase in the numbers, but that is not the case at all.
What tune did you use for an initial start? Stock tune or something from Jamie?
Steve's setup is very NB-oriented, and without some sort of additional controlling module that can translate the WB data into a log file, as is the case with the PV, it simply isn't workable (AFAIK). If it isn't practical or workable with TTS he would have an interest in denigrating WB sensors, which he does constantly without giving any evidence (that I've seen), and without it I would have to assume this is what he's trying to do. If you know of any such evidence please let me know, as I'm eager to learn.
WB sensors are used in a wide variety of applications including race cars, OEM applications since 1994, and a number of aftermarket tuning kits. I can't imagine that any meaningful inaccuracy would be acceptable in the second application, as OEM's must meet emissions regs. Bosch is the industry leader in fuel-injection and O2 sensors, and I can't see them issuing false information about the accuracy or durability of their products. I did a Google search and couldn't find any reports on inaccuracy of the Bosch LSU4 WB sensors, and from my perspective so far the only such mention has been traceable to Steve Cole.
