Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
We could ALL be tuning with TTS, if we liked the idea of riding our bikes with a RUNNING LAPTOP in our saddlebag! Go right ahead!
Are you not happy with the tuning METHOD, or are you not happy with the RESULTS? At least try it before you bail out.
I don't think that is what he was saying. I am not going to post the link, but you can google search for the TTS Mastertune Manual and VTune manual. Once you read them, you will see ALL of what is missing and what he is talking about. The level of detail is not even close.
Yes I know the products have different age, but their are key things missing from the PV manuals that will help you get a more accurate log tune. One example is that TTS recommends you zero out the Acceleration Enrichment before running Vtune..They say it gives you a more accurate tune. Now maybe the dynojet software takes that into consideration or is it just not documented? Who knows.. But the point is, it wouldn't take much for dynojet to bring up the level of documentation to something close. Keep in mind, Dynojet is the expect here, not TTS.. and the hardware works great (as you said) so all us users are asking is for someone to document it. Before rebutting, read the TTS manual and see the level of detail that is missing. The different is huge, a lot more than just putting a laptop in your saddle bag. My goal is to tune my bike, and to do it SAFELY for the motors sake.
Exactly! This is supposed to be an upgrade to TTS, not a step backwards. It's clear the device is capable but what remains a question in my mind is will DJ step up to the plate with both documentation and functionality. If you look at the TTS MT8 calibrations they do a ton of things that the Vision does not. One of my pet peeves at the moment is that I can set EIMTS with TTS but I can't do it with the Vision without going to the dealer and loading a specific calibration then sucking that calibration into VTune to modify it. What a PITA. TTS wrote their own EITMS calibration to get around this issue. I realize this is new and I am willing to give it some time, but come on, how long has DJ been tuning bikes? A lot longer than Steve Cole of TTS. I expected when I bought this unit for it to be functionally equivalent to TTS with the added capability of real time monitoring, multiple map profiles, & on screen tuning with no laptop to drag around.
PV Log tuner Basic will cover 2/3 of your calibration, this is a limitation of the sensors and the Delphi system, not Power Vision. We have been using PV Log Tuner all thru all of its development and have found that it works very, very well. To cover some of the other comments, Acc enrichment does not need to be turned off as PV Log tuner invalidates data when acc enrichement is active. Dynojet is working on better manuals, documentation, and getting more and more features released which will only get better and better. Being someone that has been in the tuning industry for a long time and having tuned thousands of bikes I can certainly say this is step forward.
Less detail in the manual doesn't mean you don't have the performance in the tuner. DJ is working on an upgraded manual, and Jamie at Fuel Moto will be writing a more detailed version for the PV Tune software. DJ manuals have not been up to the standard of their products, IMO, and I hope they put a bigger effort into the upcoming PV manual than I saw with the PCIII and PCV. That said, I'm not getting my panties in a wad and won't be abandoning PV just because competent manuals are not concurrent with the product. OTOH if a lack of detailed manuals caused me to maintain a tuning status-quo less favorable than I had before I would feel a bit less tolerant, but this isn't the case. YMMV.
Accel Enrichment is one of the mandatory logged signals, and it takes those values into consideration when writing the final tune. IMO it's just another way of approaching it, and it would seem a better way since you don't have to disable or "zero-out" anything prior to datalogging.
I hope this thread doesn't turn into an arena for high-tech religious fervor. My thrust in starting it was to exchange ideas on how to make the PV experience a better one for all owners, not a doctrinal battleground for comparing one turner vs. another.
Jamie you are a big part of why I purchased this unit. Your reputation for support and tuning is second to none. I think if it had been a stand alone unit without support from you I would not have touched it. I will say one thing though, TTS MT8 calibrations accomplish a complete tune using the narrow band sensors. TTS has a complete system that when you are finished, you have a fully tuned bike that does not rely on other calibrations or add on sensors. As far as I can tell, the Vision with proper documentation and support from DJ should accomplish the same objective. No it's not autotune, but it does result in a well tuned bike.
Me too. When I purchased the PV, I was under the impression it would at least be equal to the TTS and SEPST if not more advanced. Had I known that the AT basic/logtuner/WinPV software would only be able to tune such a small portion of the map I would have purchased one of the other tuners.
It's not like the TTS and SEPST are brand new technology, they have been out for years. I can't believe DJ would put out a "Revolutionary" new tuner/software program that aren't even set up to perform the basic functions that the "Old" tuners already on the market can. Bummer.
As noted earlier the area you are able to tune with the factory O2 sensors is a limitation of the narrowband O2 sensors i.e you are not able to tune a mixture such as WOT where you are looking for 13.0:1 when the sensors themselves can only switch from 14.3-15.0:1. You are however able to tune approx 2/3 of your VE tables where you are referencing a mixture +/- .5 stoich. You can also use the AT Wideband module which will populate the entire table to any AFR you desire.
BTW: Just so nobody thinks I am picking on the DJ Vision, I had the same discussion with Steve Cole about what the Vision does better than TTS. I want it all, and I want it now! ;-)
I know there has been much hoopla from the TTS faithful about the mysterious MT8 technology, but does anyone really understand how it works or even if it works? Could you or anyone else tell me how you can tune above 50% TP (or thereabouts) without any sort of feedback? The NB sensors don't function above that point, so how is the data retrieved? I'm not declaring that MT8 doesn't have some functional basis, but am asking you to or anyone else to explain it if it does exist.
To a very limited extent he calculates how the cam profile breathes as well as a few other new parameters to set up the base file. Once that is done you have built the base calibration then you go into tuning mode. My tuner was last updated with MT6 calibrations so I really have not played with it for a long time. I have just been reading and had a few discussions with Steve Cole, the brain behind TTS.
I do not want to make this a Power Vision vs TTS thread however plain and simple with either product it comes down to the limitations of a narrowband O2 sensor, you cannot use them to populate an area they cannot sample. There is really no magic, using TTS/V Tune will still only populate a portion of your map, the rest of the table is populated by blending the data, usually from the 70 or 80 Kpa column to the right, it also cannot correct the timing tables as you can with PV Log tuner.
