Installed PCIII map...
Old Oct 12, 2006 | 10:15 PM
pauly711's Avatar
pauly711
Default Installed PCIII map...
I just installed a PCIII and a map that is exatly like my setup: Samson rolled ovals, stock ECM(I believe it is stock- how to tell?) and Stage 1 filter, but it doesn't seem to work. IT still pops just as much on decel. I even got the message "map successfuly sent." I understand what all the numbers on the grid mean but how do I adjust the map to eliminate this problem w/o getting dynoed just yet? What numbers should I look at to play with?
Also, would riding the bike with the PCIII hooked-up to the laptop do anything? Could I use the laptop to record a real-time air/fuel curve.
Old Oct 13, 2006 | 08:37 AM
jkoch09ultra's Avatar
jkoch09ultra
Default RE: Installed PCIII map...
You can add 5's in the 0 throttle position from 1500 RPM up to 4,000 RPM. That is the column all the way to the left. If that does not stop the the popping try 10,s or 15's or 20's until it stops. I have 20's in mine. 20's will use a little more gas.
Thats how you stop the popping.
Old Oct 16, 2006 | 11:34 AM
Shrug's Avatar
Shrug
I agree with Jeff. Added 5% to mine and it did the trick. I run a stock ECM, Arlen Ness Big Sucker, and SE-2 Slip-Ons.
Did you set the zero throttle position when you installed the PCIII? Very important.
Old Oct 17, 2006 | 01:08 AM
pittguy's Avatar
pittguy
What are you guys doing about unused 02s?Leaving them in?Installing plugs?
Old Oct 17, 2006 | 03:13 PM
JollyRogers's Avatar
JollyRogers
leaving them in.
Old Oct 17, 2006 | 04:04 PM
Shrug's Avatar
Shrug
Left mine in and sealed off/secured the connectors.
128auto
Aug 19, 2008 01:11 PM
salty01
May 30, 2008 03:24 PM
beaverretriever
May 27, 2008 05:22 AM
fatbob422
May 20, 2008 02:51 PM
mhughes600
Jun 2, 2006 01:25 PM
