SERT programing ?
Old Mar 13, 2011 | 11:54 AM
RA51's Avatar
RA51
Default SERT programing ?
I have a SERT an 07 ecm it is married to an would like to program a 141 cal. into it. It gives me a error, but lets me program 176 cal. with no problem. Gets ecm info without a problem. This is not a new mastertune vci but the original SERT vci 32114-01a. What needs to be done to be able to program a 141 cal ? Ecm is married to the bike 06 Night Train thru password learn. Programed a 176 cal. to open loop an programed ecm an bike does fine but would rather have a 141 cal. to run.
Old Mar 13, 2011 | 11:56 AM
Faast Ed's Avatar
Faast Ed
Likely need a newer version of software for your laptop.
Old Mar 13, 2011 | 12:21 PM
RA51's Avatar
RA51
As far as I know the 4.77 software was the last for the SERT. The MasterTune software will not work with it.
Old Mar 13, 2011 | 01:51 PM
Faast Ed's Avatar
Faast Ed
Every 141 file I click on lists it as an 06 bike and the 176 files are listed as 07's (in the edit notes window).
Other than cut/paste into a newly created file of your own, I think you are running out of options.
Just for grins,..... I wonder if 'renaming' a 141 file would work? (Reaching for straws here). Changing the first three numbers to 176?
Just put on some safety goggles first, incase it explodes. LOL
EDIT: On second thought, I don't know if running that map is a good idea. The ecm's might have enough difference that the 06 map would not work accurately in the 07 ECM.
Old Mar 13, 2011 | 02:25 PM
RA51's Avatar
RA51
Tried renaming would not work. I intended to run this on my 06 Night Train. That is why I wanted to use the 141 cal. Just bought this sert an ecm play with as I have 2 SESPT an ecms. One of the ecms is a 07 dyna marreid to one of the sespt. I can program any map I want to the ecm. I just thought the sert would work the same way. If I can not get it done then I will just put it on the 09 Dyna I have.
Old Mar 13, 2011 | 02:32 PM
Faast Ed's Avatar
Faast Ed
Seems that you ought to be able to manually change the cells in a 176 map to match your preferred 141 map. Long and tedious.
Oh, crap again. It would still be an 07 map in an 06. Would be interesting to see if it would work.
Old Mar 13, 2011 | 02:40 PM
RA51's Avatar
RA51
That is basicly what I have done so far. Programed a 176 with map in open loop an not closed loop. So far has not thrown any codes.
Village Idiot™
Mar 10, 2012 01:29 AM
supernova
Apr 27, 2008 05:31 PM
06 Ultra
14
Aug 9, 2007 06:31 PM
Josey Wales
Jun 10, 2007 03:18 PM
arachman
Jul 23, 2006 12:11 AM
