Powercommander Help Please?
Old Oct 29, 2006 | 09:22 PM
mlbuckner's Avatar
mlbuckner
Default Powercommander Help Please?
Just recently had my powercommander replaced under warranty. Device threw a device code 39 error and the serial number would show with strange character and incorrect numbers, would not take a map and when looking at the rpm range on the unit it went up to 20,000. Dynoject said the firmware went south.
Now the second unit has done the same, does anyone know what may be causing this to happen. Debating on reguesting a refund and going with sert. Beginning to think powercommander has a defect in the software or vram system. I am wondering if there is a limit to how many times you can send a map to the pcIIIusb before it fails like this.
Tried the reset did not work and when I try to send a map it give error incompatible error. Any help or thoughts greatly appreciated.
Bike is a 2006 Road King Classic
Stage 1 Race Use Only 25 degree injectors
Stage 1 Breather with K&N Filter
Rush Slip on Mufflers with 2.5 baffles
Matt
Old Oct 30, 2006 | 02:25 AM
Rhubarb's Avatar
Rhubarb
Default RE: Powercommander Help Please?
Make sure you don't have any pinched wires in the harness.
Maybe a short is taking it out...
Old Oct 30, 2006 | 02:39 PM
nvsteve's Avatar
nvsteve
Very important to put dialectric grease on the connectors.
Old Oct 30, 2006 | 05:24 PM
mlbuckner's Avatar
mlbuckner
What is the purpose of the dielectric grease, I would think that if it were that important they would provide it with the unit instead of merly suggesting the use of it.
Old Oct 30, 2006 | 05:26 PM
anubisss's Avatar
anubisss
Keeps the water out...
Old Nov 2, 2006 | 12:46 PM
swagner75's Avatar
swagner75
Stage III
I think you have the right idea to request a refund and replace it with a SERT.
Old Nov 2, 2006 | 12:53 PM
sleepneagle's Avatar
sleepneagle
Hey Matt, your bike isn't modified enough to need a PCIII, just go with a sert. See you at the next meeting.
Old Nov 2, 2006 | 03:18 PM
sleepneagle
Matt,
You haven't changed plugs and/or plug wires have you? Where did you mount the PC? Not close to coil or starter?
hddave2
Apr 26, 2009 11:44 AM
BK2
Jul 15, 2008 02:12 PM
DaveJ
Exhaust System Topics
May 11, 2007 09:00 PM
HD Jake
Sep 18, 2006 06:34 PM
killer.com
Aug 26, 2006 08:58 PM
