SERT experts-need help!!
Old Aug 26, 2006 | 01:16 PM
killer.com's Avatar
killer.com
Default SERT experts-need help!!
Ok-I'm finally setup to try and hookup to the bike. Questions are-1. Is the hookup in the fuse box? 2. When I hookup it up and turn the ignition on, will it show me the map that is installed and what the settings are? 3. I'm hopeing to save the map, and use it for reference in case the changes I make are not good ones? Thanks, Eric
Old Aug 26, 2006 | 08:58 PM
kpreese's Avatar
kpreese
Default RE: SERT experts-need help!!
Hey Eric,
1. Yes, the connector is in the electrical caddy.
2. Don't forget to turn on the run switch in addition to the key switch. This stumped me for a nervous 5 minutes or so the first time I tried to use it.
3. To the best of my knowledge, you CANNOT retrieve the map stored on the bike. I believe you can obtain a code to help determine the version you are running. This is only helpful for identifying which map and so it is only useful if you already have the map. I can't remember what they call this code (possibly "version") and my SERT isn't installed on this computer so I can't check right now. When creating your own maps, you would set this code so you'll be able to keep track of which custom map you are using.
The SERT software comes with the stage 1 downloads and some other combos, but I don't think it comes with the stock maps. If I'm wrong, someone will step in pretty quick and help out.
Kevin
hardav23
Apr 5, 2008 02:13 PM
mvent
Dec 4, 2007 11:26 AM
cwalms
Jun 15, 2007 12:59 AM
BTD
16
Apr 28, 2007 07:52 PM
clayman
Jul 23, 2006 01:07 AM
