Ignition table on PCIIIusb
Old Nov 3, 2006 | 12:43 AM
Dsanchez's Avatar
Dsanchez
Default Ignition table on PCIIIusb
Any body understand or experiment with the ignition table side of the PCIII ?
Old Nov 3, 2006 | 09:51 AM
cwsharp's Avatar
cwsharp
Default RE: Ignition table on PCIIIusb
I have seen a map that adjusted the timing for a bike with ac and pipes only, but when I had mine dyno'd they said that they don't mess with timing unless you change cams...
Just like a car...
I'm happy with the results and so I can't disagree with them. Before I had the dyno work done, I ran the custom map that was supposedly for my bike with the ac and pipes that had been from another bike... and the map that I ended up with from the dyno tune is much better than the one that had the ignition timing "tweaked".
C#
Old Nov 3, 2006 | 05:51 PM
nvsteve's Avatar
nvsteve
If you don't have any issues it's probably wise not to mees with it.
My tuner added 5 to all columns in the 0 throttle position to prevent
decel popping. If that's an issue for you, it's worth a try.
There are also some additions @ 80 and 100 throttle positions.
petejoe43
The Dyno Room
Jul 10, 2017 06:51 PM
jackinthebox
Apr 8, 2012 11:07 PM
dchoran
Aug 26, 2007 09:25 AM
cglofland
Jun 7, 2007 09:34 AM
pdexter
Jan 13, 2007 10:50 AM
