PCIII igintion table
Old Apr 7, 2012 | 10:18 PM
jackinthebox's Avatar
jackinthebox
Default PCIII igintion table
I have -3 in my canned map in the cruising range 20-60%. What would I gain if i put them to -2 instead. Does the negative number mean it retarding timing to reduce pinging issues?
Old Apr 8, 2012 | 07:41 AM
nvsteve's Avatar
nvsteve
Interesting. I have multiple maps that I've tried. Some from being dynoed and others are canned. None of them have negative changes in that range, In fact they are all at 0. There are some increases at higher rpm and throttle position.
Old Apr 8, 2012 | 11:07 PM
X Iron Butt's Avatar
X Iron Butt
If there are negatives they were probably done on a DYNO tune. Remember the PCIII is just modifying what the ECM is doing. The ECM could have + 4 there and the DYNO tune showed to take 3 away. I havent seen all or near all but have not seen a canned map with any ignition adjustments below WOT that were not emission controlled exhaust valve disabled MAPS. Where did you get them?
rocky5
Jan 6, 2012 08:06 AM
Molzy
Dec 19, 2009 08:22 AM
beanok
May 21, 2009 08:11 PM
Tltrump
May 21, 2008 12:55 AM
WARG
Feb 4, 2007 06:33 PM
