1994 Fatboy.....NEED HELP
Old Jun 27, 2011 | 09:35 PM
Broham@brokenspokecycle's Avatar
6th Gear
Default 1994 Fatboy.....NEED HELP
Ok so I got my bike out of the garage fired it up and rode down to the car wash and did a quick spray down as always careful not to get the electronics or air filter wet, like I have done a hundred other times. My bike is now back firing out of the carb and pipes and it sounds like my carb is trying really hard to suck air....I am lost! I took plugs and wires off checked the coil for moisture. I have no clue what is going on. PLEASE HELP. Also I am running Autolite 64 plugs, XXX plug wires, and a Vodoo coil.
Last edited by Broham@brokenspokecycle; Jun 27, 2011 at 09:38 PM. Reason: Forgot some info
Old Jun 28, 2011 | 08:30 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Get a hair dryer and dry out your fuse box, remove each fuse one at a time, dry the socket & coat the fuse prongs with dielectric grease and re-install. Then dry the handlebar switches and ignition switch.
Old Jun 28, 2011 | 10:48 PM
Little T's Avatar
Little T
Could also be bad wires if you dry the bike off and it runs fine try spraying plug wires and see if it affects it
thumbbuster
Nov 9, 2017 03:12 PM
fame2
EVO
Dec 18, 2014 05:58 PM
Keith_71
Jul 30, 2011 05:35 PM
jkottke58
Shovelhead
11
Jun 26, 2011 08:58 PM
FandA M
Nov 13, 2007 04:37 PM
