Turn Signals
Old Jul 12, 2005 | 01:00 PM
Kyohn's Avatar
Kyohn
Stage I
Default Turn Signals
I have a 2004 Heritage Springer, Just recently when I go to start the engine the 4 ways flash 5 times, bike does not have a security system. Any thoughts? Does not effect engine starting or anything else.
Old Jul 12, 2005 | 01:38 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Turn Signals
Probably throwing a code. Check with your dealer so they can clear it and tell you what it was.
Terry
Old Jul 12, 2005 | 04:47 PM
HDF Tech's Avatar
HDF Tech
ORIGINAL: Kyohn
This will explain your flashing lights https://www.hdforums.com/m_66685/tm.htm
Old Jul 12, 2005 | 10:33 PM
tobster's Avatar
tobster
Terry and TCSTD know what they are talking about...just had the same problem with my 02 EG Classic after I upgraded to LED lights...Once I put an equalizer on the bike I went through the process that Terry and TCSTD mentioned and it took care of the problem.
For some reason you are throwing an error code and your ECM needs reset.
Good Luck...mine about drove me nuts getting it figured out..... there is a lot of knowledge and experience on this forum...!
Tobster
b1gj0n44
Mar 20, 2017 02:51 PM
MCT
May 18, 2010 09:39 PM
Seascape
Aug 28, 2009 03:31 PM
k3rodgers@sbcglobal.net
Jul 11, 2009 09:36 AM
HOGRIDA_06
May 10, 2009 04:09 PM
