50 amp 3 phase conversion
Old Aug 23, 2011 | 06:38 PM
NitroBerserker's Avatar
NitroBerserker
Default 50 amp 3 phase conversion
Has any one done this with the stock later model Harley parts? I am aware of the Cycle Electric set-up I just don't like the way the regulator mounts on that one...
This will be on a 2001 FLHTC .. extra lights, fogs and brighter spots, big starter ( 1.6 K ) heated grips, amp for the radio, sometimes heated clothes... anyway I use a lot of juice.
been having some electrical issues lately, I found the stator wires had rubbed through in two places. fixed that and the stator seem to test ok, no shorts at least. I don't have an AC tester though to check output.
Got the battery on charge now and will see how it acts tommorrow. When I started it up it only went to 13.6 V not 14.7 like I expected but the battery was pretty far down.
I know I would have to replace the whole shebang, stator rotor and regulator but from Chicago HD the price is inline with the Cycle Electric kit.
what I really want to know is will this setup bolt up? and any thing I should look out for..
Old Aug 23, 2011 | 06:43 PM
Dallas 13's Avatar
Dallas 13
You won't get full voltage from the system until you rev to at least 2000RPM.
Old Aug 23, 2011 | 07:26 PM
NitroBerserker
Yeah... I had the multi-meter on it and I was twisting it up to 3000-3500 in the garage when I was getting those low readings...
Old Aug 25, 2011 | 02:39 AM
NitroBerserker
okay, I guess 13.6 is a good reading......
Turns out my Big Boar 1000 battery wouldn't hold up under an improvised load test. so I'm trying another battery.
Old Aug 25, 2011 | 02:48 AM
Stiggy's Avatar
Stiggy
I have the Compu Fire 3 phase system on my '00 FLTRSEI and am a huge fan. First off, longevity: Replaced stockers at 19,000, 32,000 and at 52,000 went with the 3 phase. 40,000 miles later, (and about 2 years,) it never fails to hold a steady 13.0 - 13.5 volts at 2000 and up, no matter that I'm running the Tour Pak, or the heated gear, ( 12 month rider.)
The system is skinnier, and they send spacers to assist in that you won't be using the stock pieces. The rotor is also vented. There's a 45 amp fuse in the line going to the battery.
Very pleased, paid about $400 through Drag Specialties.
JonnyVegas
Oct 25, 2017 07:27 PM
IRON1250
EVO
67
Jun 4, 2017 09:33 AM
fenders
Shovelhead
Jun 23, 2014 06:34 PM
tmatador
Feb 13, 2009 08:26 AM
Godeater
Apr 30, 2006 10:47 AM
