I fried something
Old Sep 17, 2011 | 08:50 PM
guyrudy5's Avatar
guyrudy5
4th Gear
Default I fried something
I have a 97 King that was EFI that I put a carb on and a Dyna dual fire ignition. I ran a ground wire from the starter mounting bolt to the frame.( since its rubber mounted and this bike is a rebuild) Started good ran good. But on the maiden voyage to the end of the block and back (I didnt get out of first gear) it shut down and smoked out. All the smoke was from the insulation burning off that ground wire, thats it! But now she wont click,tick,burp or fart NOTHING. The only other thing I noticed is the coil got really HOT, and stayed that way for a long time after the failure. Any Ideas?..old stories?..jokes?..good phone numbers?
Old Sep 17, 2011 | 10:32 PM
Chunk's Avatar
Chunk
See if this don't help explain it--
www.cyclemaintenance.com/elec/electrical.htm
Old Sep 22, 2011 | 05:53 AM
guyrudy5's Avatar
guyrudy5
4th Gear
Default still need help....please?
The voltage regulator for 97 and newer has 4 wires, 2 are already fixed in a plug for the stator. one goes back to the 30 amp circut breaker, where does the other go?
and my coil only has two post all the diagrams I have showe 3?
And the starter relay. All the diagrams and web sights explain what they do, I just want to know what wire goes from this prong to this device or growned or terminal theres only 4 wires where do they go? I have a dyna dual fire ignition and a stock coil and stock regulator.
hardheaded
Shovelhead
17
May 29, 2019 08:05 AM
johnmck
General Topics/Tech Tips
May 17, 2018 09:36 PM
ncottrell2009
Ironhead
Oct 16, 2012 06:29 PM
Sea_Dog
EVO
18
Sep 6, 2012 07:52 PM
Sea_Dog
Aug 22, 2012 07:07 AM
