Fuel Gauge and Send Unit - Diagnosis
Old Nov 23, 2011 | 09:09 PM
OneBlackFly's Avatar
OneBlackFly
Default Fuel Gauge and Send Unit - Diagnosis
Fuel gauge does not work, always reads full. Where can I find a detailed procedure to diagnosis the problem? I've not found anything in the service manual. Thanks.
Old Nov 24, 2011 | 01:12 PM
Dallas 13's Avatar
Dallas 13
Might consult the electrical diagnostic manual for your bike. One of the first purchases I get for a bike is the manuals. They cost a few bucks, but save me a lot more.
Old Nov 24, 2011 | 02:19 PM
OneBlackFly
Thanks Dallas for this suggestion. I know where to get one, but I believe the problem is a mechanical one (I think the sender unit sticks), but I'm not sure. Wish there was a better system though.
Old Nov 24, 2011 | 02:28 PM
soft 02's Avatar
soft 02
Can you see the float rod through the filler hole?
Old Nov 24, 2011 | 02:37 PM
OneBlackFly
Unfortunately, no. If I could, then I might be able to un-stick it (if that was the problem) or maybe even move it up and down to work the gauge/sender assembly. I have to remove the tank hole cover assembly under the console to get into the tank.
Old Nov 24, 2011 | 02:44 PM
soft 02's Avatar
soft 02
Have you tried to unplug the sender so it zero's. Its not that hard to pull the fuel tank console. Not a bad time to service the fuel filter. Pull the sender and ohm it.
bigdaddy33
Sep 16, 2015 06:31 PM
grbrown
EVO
20
Mar 28, 2015 05:22 AM
douggyjb
Apr 20, 2012 08:01 PM
aloxdaddy99
Jul 31, 2011 06:39 PM
raygk9
EVO
Apr 6, 2011 04:42 PM
