07 intake- PCIIIUSB map
Old Dec 4, 2006 | 08:34 AM
07sophtayl's Avatar
07sophtayl
Default 07 intake- PCIIIUSB map
Hi All,
I recently bought an 07 softail standard, and am currently going through some enhancements......
I have purchased a Pro R hypercharger, am fabricating a set of custom Big Radius pipes and have a PCIII USB.
Now the question is wrt the map to use.
The PC website has a map as follows:
2007 Harley Davidson Softail models
Vance & Hines Big Radius drag pipes
Screamin' Eagle Air filter
Stock ECM
Dynojet O2 sensor eliminators installed
Rev Xtend enabled
Are the SE Air filter and the Pro R Hypercharger close enough in airflow that the map will be interchangeable or are they significantly different?
thanks in advance
Mick
Old Dec 4, 2006 | 11:48 AM
maddog53's Avatar
maddog53
Default RE: 07 intake- PCIIIUSB map
Had the Pro R Hype,, so save your money.
S/E AC's perfoamance was much better than the hpyerchanger.
No more said, so good luck with the new bike...
07bobber
Jan 14, 2011 01:44 PM
rbabos
Dec 30, 2007 08:54 AM
Dr_J
May 20, 2007 11:41 PM
bks6721
Mar 11, 2007 12:43 AM
mikeurig
Oct 19, 2006 10:59 AM
