07 with SE AC but stock pipes
Old Dec 14, 2006 | 11:47 AM
07ultra07's Avatar
07ultra07
Stage I
Default 07 with SE AC but stock pipes
Newbie trying to find answers to a couple of questions, hopefully someone can help
If you have the SE Air Cleaner but still have STOCK pipes.. What ECU flash do u request ? Stage 1 ??
What is the number ?
How much power do you lose by opening up just the intake side with the SE AC ? Is it significant ? I like it fairly quiet
Old Dec 14, 2006 | 06:21 PM
maddog53's Avatar
maddog53
Default RE: 07 with SE AC but stock pipes
If your not going to go witth new pipes, save your money.
Keep it STOCK !!
Old Dec 14, 2006 | 09:15 PM
Road Glider's Avatar
Road Glider
O7 Ultra,
You need the stage 1 download when you change the intake (dealer does it). If you just changed the exhaust only then you wouldn't need to change anything. The stock bike is running lean and when you open up the intake you'll run even leaner which may damage the motor.
Road Glider
07 Road Glide
SE Touring Mufflers
SE Air Cleaner
Old Dec 15, 2006 | 08:19 PM
BlkSilverado's Avatar
BlkSilverado
I'm glad you asked the question, and I'm interested in the same thing... I'm watching for someone to have a tune that is downloadable with the SERT. I've got the race tuner and stage 1 air cleaner kit here allready, but have been waiting for the exhaust (Reinharts) for quite a while... With more waiting time coming. I'd like to put on the air cleaner, but know it will run way lean without a map update of some kind. Anyone have a map for a stage 1 intake stock pipes for a 07 Ultra?
Old Dec 15, 2006 | 08:28 PM
Beagle1's Avatar
Beagle1
ORIGINAL: BlkSilverado
Yes, it will.
You need a download more for intake mods than exhaust. Don't cut corners on intake mods unless you like buying pistons.
Old Dec 16, 2006 | 12:31 AM
Dsanchez's Avatar
Dsanchez
You DON't need the stage one download if you use a tuner like the PCIII or SERT. I wouldn't waste money on the STAGE 1 download...put your money toward a PC.
Old Dec 16, 2006 | 02:29 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
I know plenty of bikes running fine with slip ons and ac's and stock cals.
Old Dec 16, 2006 | 04:57 AM
Dsanchez's Avatar
Dsanchez
Fine is one thing. Efficient, effective, and maximizing its abilities is another.
Old Dec 17, 2006 | 04:06 PM
One_Screamin_Eagle
ORIGINAL: Dsanchez
It's a stock bike with stock mufflers and an SE air cleaner. You are dillusional if you think a dyno tune is going to do anything significant ove the flash.
Old Dec 17, 2006 | 05:09 PM
Carrjim's Avatar
Carrjim
But what flash stage 1 or stock ? That is the core of the question
