Voltage Regulator going bad?
Old Mar 21, 2012 | 08:43 PM
gambler's Avatar
gambler
Default Voltage Regulator going bad?
Tonight I noticed my lights getting dim, then bright, once every minute or so. The voltage gauge would also swing between 12 to 14 volts when this happened. I suspect the voltage regulator is going bad. The bike is a 2005 Ultra with 65,000 miles, and it is the original regulator. Opinions?
Thanks.
Old Mar 23, 2012 | 04:34 AM
grbrown's Avatar
grbrown
If you have the factory service manual there is a series of tests you can do to identify any charging fault. There is also an excellent thread here on HDF, although it may take some finding. I think it is by 'Dr Hess' in the Evo section.
Old Mar 23, 2012 | 05:33 AM
grbrown's Avatar
grbrown
Here's an alternative thread. Hope it helps!
Old Mar 23, 2012 | 11:14 AM
gambler's Avatar
gambler
Thanks for the links. I ended up getting a new battery (it was four years old) and a new regulator. That cured the problem. I suspected the regulator was bad, and it probably damaged the battery (I'm sure it didn't help it, anyway).
Old Mar 23, 2012 | 11:22 AM
grbrown's Avatar
grbrown
Do check that you are getting a good charge, to ensure your alternator is sound. With a fresh battery you can get by for a while if you still have a problem! Don't want a repeat in a few week's time.....
Old Mar 23, 2012 | 01:10 PM
gambler's Avatar
gambler
Had a new stator put in about six months ago when they did the cams, so I should be good to go. The voltage meter on the bike in acting more normal now, too. Thanks for the advice, I appreciate it.
Goose_NC
Electrical/Lighting/Alarm
19
Aug 13, 2018 03:24 AM
05flhtcui89
Apr 19, 2018 11:43 AM
Sardo
May 7, 2017 10:42 AM
Arjeje
General Topics/Tech Tips
Feb 18, 2016 10:21 AM
Lingleha
Jul 8, 2012 05:34 PM
