front cyclinder not running
Old Apr 16, 2012 | 04:14 PM
acegarp's Avatar
acegarp
Stage III
Default front cyclinder not running
Hi,
Iv'e a 2005 fatboy front cyclinder not running ,have changed plugs,leads ,fuel and coil.
After checking out some of the posts on this forum, i ran the bikes own diagnostics and got a fault code of 1352 looked it up as (front ign coil high/efi shorted)
so whats it telling me and where do i go from here,and don't say put a carb on it..
all help greatly appreciated
Thanks
Old Apr 16, 2012 | 05:14 PM
Steel Wheels's Avatar
Steel Wheels
If it's easy to do, swap plug wires at the coils and see if it moves - not sure where they're at on yours...if no change, try swapping coils.
And I'd never advise anyone to get rid of the EFI.
Old Apr 16, 2012 | 05:19 PM
Steel Wheels
"have changed plugs,leads ,fuel and coil."
DOH! Ignore 1st post. It could be the DTC set during replacement. Has it reset since clearing? And is compression good?
Old Apr 18, 2012 | 02:55 PM
acegarp's Avatar
acegarp
Stage III
compression fine, still don't understand what the fault code is trying to tell me, so should i just give up and let my local dealer charge me a 100 bucks an hour to tell me they don't know what was wrong but changed every conceivable part until it works,,,(and charge me acordingly)
not sure my pockets are that deep
Old Apr 18, 2012 | 03:09 PM
Big Trev's Avatar
Big Trev
Front cylinder injector?
Old Apr 18, 2012 | 04:20 PM
acegarp's Avatar
acegarp
Stage III
thanks big trev
i'll try and look at it over the weekend.........
Old Apr 18, 2012 | 08:45 PM
Steel Wheels
What he said. You can measure resistance seeing as it's dead all the time, or swap the two and again see if it changes cylinders.
Keep us posted - if nothing changes by swapping it over, you might rig a noid light and check injector pulse.
motochick55
33
Aug 10, 2019 03:54 PM
StillOkie
15
Apr 2, 2018 09:14 PM
DragonArm
Jul 16, 2013 10:59 AM
omgtkk
EVO
41
Oct 18, 2010 05:43 AM
convictedsoul
Sep 28, 2010 10:45 PM
