turnsignal module testing?
Old Apr 21, 2012 | 12:43 PM
dirtracer27x's Avatar
dirtracer27x
Default turnsignal module testing?
ok so i have a issue,i bought some auto gem babybullets for my 2000 road glide,went to install them and they are only single filament.no biggie as i will just hook up as turn signals and bypass the running lights.i had everything situated and they worked fine,soldered shrink-wrapped and then a few minutes later they quite working.no they both just turn on and don't blink,like when a bulb is burnt out.so i checked the rear bulb and it is fine,all fuses good.my next step was to check the turnsigal module,left side works fine so far and i found a red wire in the plug harness on the module that pulsates the voltage for left side.but the right side it seems i have no pusateing voltage,aim i testing this correctly? thanks for the info
Old Apr 21, 2012 | 12:58 PM
trozenhorse's Avatar
trozenhorse
subscribed......i have a similar issue, sometimes it flashes sometimes it doesnt, but mine are stock.
Old Apr 21, 2012 | 01:24 PM
dirtracer27x
lol,now i did the left side and same thing,what a night mare for some little blinkers.
Old May 15, 2018 | 02:06 AM
frenchbrapper's Avatar
frenchbrapper
Update please having same issue
thinking it’s module. All lights are on at all times. And slowly dim out. Unplugged module tested in harness and everything works from switches. Then when plug in everything lights up again
buellrider76
Apr 24, 2014 08:38 PM
Keithhu
May 16, 2013 10:45 AM
HDFatboy98
Nov 30, 2012 11:07 AM
Joboo1966
EVO
21
Apr 15, 2012 12:25 PM
nkauf21
May 2, 2010 05:40 PM
