Advice Needed - Limp Mode?
Question, bike is still in warranty, should I take it to service, should I check the plug down around TB that I hear usually causes this, should I connect my PV and check for codes? Or was this just a fluke due to turning off and restarting and likely never happen again? What do ya'll think is appropriate thing to check?
However pulling that plug and giving the contacts a clean and using some dielectric grease seems to fix the problem.
If not doing the same at the ECM under the seat can also help and I should point out that since doing both to my 2009 Ultra in 2009 I have not had the problem reoccur.
You should see
P S S P E
one or more of the above maybe flashing and if it is press your odometer button and write down what codes you may have present.
http://www.youtube.com/watch?v=RTy_JKI9cQ0
Current Root Cause Investigation It is believed that fretting corrosion is a major contributor, Poor ECM connections seem to be the most likely cause.
When this hapened to me we were in the left hand lane of thick traffic riding along at 80 mph when she went into limp mode.
You may not have the same situation as I did but until you retrieve your codes you will not know. Your bike stores these codes until its told to reset to zero.
Let us know what you find.
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing
speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting
sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should
illuminate. The word diag should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with
the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing
is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back
to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button
in for 5 seconds and release. If there are any DTCs the code will be
displayed or the word none will appear if there are no DTCs. Push the odometer reset
button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTCs are not to be cleared, Press and release the odometer reset button. Part
number of module will be displayed.
https://www.hdforums.com/forum/sportster-models/685326-run-your-own-diagnostics.html
https://www.hdforums.com/forum/touri...511-p2101.html
