Limp home mode/TPS
Old Feb 25, 2011 | 06:02 AM
fgunnr's Avatar
fgunnr
Default Limp home mode/TPS
I took my 2009 Roadglide to the dealer for it's annual service. I had noticed the engine light flicker from time to time without any problem. When the tech rode the bike after the service the light stayed on and the bike went into the limp home mode. He hooked it up to the computer and the problem is with the throttle position sensor.
That is all I know now. Anyone experience this?
thanks
Old Feb 25, 2011 | 06:11 AM
Mike T's Avatar
Mike T
Sensor's go out periodically. Nothing to be concerned about.
Old Feb 25, 2011 | 09:29 AM
fgunnr's Avatar
fgunnr
Mechanic found the problem. The ecm connection was loose.
Old Feb 25, 2011 | 02:15 PM
JohnScrip's Avatar
JohnScrip
May have had the same problem -- Instruction (to the tech, from the MoCo) was to replace certain connectors and wiring to the ECM. "Limped" several times on my 2011 since I picked it up. Never left me stranded, always reset after (5x ign on/off), more of a nuisance than anything else.
Old May 29, 2011 | 11:20 PM
drspencer's Avatar
drspencer
Could you please explain the 5X reset procedure?
Thanks
Old May 30, 2011 | 03:16 AM
Hog Heaven's Avatar
Hog Heaven
I think he's referring to cycling your ignition switch on and off 5 times.
Old May 30, 2011 | 04:54 AM
swestbrook60's Avatar
swestbrook60
thanks
My '08 Ultra did the same time. First couple times it stopped after I had checked some things out such as ignition reset, plugs, wires, etc. The it would run fine for a while and go into Limp Mode again. The last time it was running fine until I did a rolling stop at a stop sign and when I took off I was in Limp Mode again. I limped to the dealer (only a couple miles) and it was my throttle position sensor. It was covered under warranty though.
Old May 30, 2011 | 07:03 AM
Geezr Glidr's Avatar
Geezr Glidr
My 09 EG Classic did it too. I never did the 5x thing, but after I pulled it over & shut it down for 10 seconds, I fired it back up & it could be fine for 2 months, or it could do it again in another 2 miles. It was a warranty thing. It's fine now. It was corroded connectors.
Old May 30, 2011 | 07:38 AM
lionsm13's Avatar
lionsm13
Dialectic Grease helps/insulates those connectors.
Wonderful stuff..
Great for spark plug boots too.
Keeps water out..
Haarley
Dec 10, 2018 12:14 PM
mja52403
Apr 30, 2017 12:31 AM
BBQHOG
Jan 8, 2013 11:10 AM
BigDaddyMike
Jun 15, 2011 11:49 AM
Crowdog
Oct 31, 2005 01:10 PM
