ECM Hacking
Old May 27, 2012 | 02:57 PM
DavTN's Avatar
DavTN
Question ECM Hacking
There are a number of options for hacking a car/truck, but is there anything for our bikes?
I have a tuner, but accessing the ECM directly opens many more options. Calibrate speedo, fuel gauge, spark tables, security codes, voltage and much more.
The only thing that came up via search was how to make a Mac emulate windows to connect with the SE tuner.
My mustang had multiple tunes based on a number of variables, air temp, track temp, Econ tune for longer trips....all which I could change on my laptop plugged into the obd port. A restore of the original avoids the warranty issues. Very similar to hacking a PC bios to unlock all the options.
Can someone point me in the right direction? I can blaze the trail if needed but would prefer not to waste my time if it already exists.
Thanks
Old May 27, 2012 | 03:45 PM
TickTock's Avatar
TickTock
Thanks
SERT, TTS, Power Vision. All three will get you into the ECM. You just have to pay for the rights to the software.
Old May 27, 2012 | 06:57 PM
DavTN's Avatar
DavTN
Thanks for the response. I have the PV and it does a lot, especially with winpv but does not unlock everything or let you adjust all of the values. It does capture/insert multiple streams but not wide open. Say for example you wanted to change the security pin by just typing the new value on the laptop or change when the low fuel light comes on.....
Also, most of the tuners make you turn off the engine to remap, this helps them avoid issues and keeps instructions easy but not all value changes require a restart....many cars have a sport mode switch why not make one for our bikes....
I know there are members that have written apps so I bet someone has been down this road before. Anyone able to capture (read/write) all data streams, FI, CANbus, DTII, etc?
Old May 27, 2012 | 10:07 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
Might check this guy. He used to be on the forum.
http://www.tunemyharley.com/
redbeard_trucks
43
Nov 3, 2025 07:46 PM
degeyter@live.com
May 11, 2017 01:27 PM
NativeTexican
23
Jul 5, 2012 12:55 AM
DHart
Oct 1, 2009 10:22 AM
ct555
Apr 2, 2009 10:00 AM
