fuel management software for windows
Old May 8, 2017 | 06:08 PM
degeyter@live.com's Avatar
degeyter@live.com
Stage II
Default fuel management software for windows
i havea few friends, encluding myself that want to check the mapping, and changing some of the perameters, and, or adding tunners how do i go about getting the software to check different tunners, or stock ecm
Old May 8, 2017 | 09:30 PM
WKNDS's Avatar
WKNDS
I think the TTS Mastertune suite of s/w will do what you want.
However, for the programming part it, it is licensed for only one bike
(unless you buy the two bike part #). It will 'marry' itself to one bike
and you can not use it to program a different bike.
However, the Datamaster program (part of the suite of TTS tools), can
be used to read/analyize the data stream from any HD bike.
Obviously, you must have the 'correct' style data cable for the year
of the bike in question (CAN bus, J1850, etc) ...
http://www.mastertune.net/products_mastertune.html
hope this helps,
T.
Old May 9, 2017 | 02:34 AM
Gordon61's Avatar
Gordon61
You will need to buy one of the flash tuners discussed in the forum here. A tuner is needed to be able to interface to the bike's ECU and then each tuner has it's own software.
There is no free stuff if that is what you are asking
Best to check out the Ignition/Tuner/ECM/Fuel Injection forum
Old May 10, 2017 | 01:21 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Old May 11, 2017 | 01:27 PM
hattitude's Avatar
hattitude
As mentioned, if you want to mess around with the tune on your bike, it will cost you the amount of buying a tuner .....
Now, if you just want to see what is in a tune, what you can monitor and change, just for the education of it....
Disclaimer: I have owned (and really like) my PowerVision PV-1 tuner for about 6 years... I did this prior to purchase to see what I would be getting into... I don't know if if this is still available for non-PV owners... I do know I can still work in WinPV software without my PV attached, so I suspect it still works.... You will not be able to see, or modify your actual tune this way... it's just for info only..
Go to FuelMoto website, select EFI Tuners, select PowerVision, then above the description are a line of tabs.... one is downloads..You used to be able to download a working copy of the "Power Vision Software", I believe it is a copy of WinPV, which allows you manually adjust PowerVision tunes.
Then go to the DynoJet web site. Along the top, right are some tabs. Select "tunes", enter a bike, and you will be able to download tunes for that bike & different mods.
Now you will be able to select a tune with the PowerVision software, and page through the different aspects of the tune... it's an education to be sure..
prerender
Sep 6, 2019 10:19 AM
harleyrider4300
May 27, 2017 01:00 PM
Timpechos
Oct 2, 2012 10:14 PM
pacificrider
Jul 11, 2010 08:48 PM
Doc 1
Vendor For Sale Classifieds
Nov 17, 2008 08:31 PM
