Tail Light Wiring
Old Jan 17, 2007 | 06:00 PM
magnoliarunner's Avatar
magnoliarunner
Default Tail Light Wiring
I just installed front turn signal assemblies on the rear of my '05 Ultra to have additional rear running lights.
Stock rear assemblies have a single filament bulb. Stock fronts have dual filament bulbs.
I now have 2 wires that need to be tiedinto the tail light wiringcircuit somewhere.
1. Should I tie into the tail light wiring harness where it plugs in? (before the printed circuit)
or
2. Should I tie intothe tail light/tag lightassembly wire? (after the printed circuir)
or
3. Should I tie into the rear fender tip wire? (after the printed circuit)
Will it cause the solder joints to overheat if I tie in after the printed circuit?
Will I need a higher amp fuse?
Just being cautious.
Thanks for your help,
magnoliarunner
Old Jan 17, 2007 | 10:01 PM
disturbedvn's Avatar
disturbedvn
4th Gear
Default RE: Tail Light Wiring
Not sure why you put frt. lamps on rear you should have just put in the HD MOD. that converts to rears into running lamps cost around $40.00. any way look for the blue wire in the that plug into the board this is you running lamp. Tap at the harness before the board less chance of damage good luck.
[IMG]local://upfiles/22879/BC10118A4CD74A5EA42BE9869FD51ADA.jpg[/IMG]
extremeshot
Electrical/Lighting/Alarm
Sep 14, 2018 08:27 AM
Henway
Jun 19, 2017 07:29 AM
chuckw2
Dec 26, 2014 02:14 PM
emerican19
Jan 9, 2013 10:16 PM
vindyl
Apr 16, 2011 07:29 AM
