Tricky Starting
Old Jan 25, 2007 | 12:37 AM
EasyJoe's Avatar
EasyJoe
Default Tricky Starting
Help!
I have a 1992 Softail custom. When I push the starter button in clicks. One click each push. Most of the time it starts, somtimes first
try and some times after repeated tries. I thought there was a dead spot in the starter so I replaced it, but no change. It seems to work first time with a full charge, but as the day goes on with stops and starts it gets worse until I need a push. Shop couldn't figure it out.
I like to take two or three day rides and I don't want to get stranded. Any suggestion?
Thanks in advance, Joe
Old Jan 25, 2007 | 12:51 AM
badmo's Avatar
badmo
Default RE: Tricky Starting
Sounds like a possible short. Multimeterthe starter leadsand see if it shows the same value each push of the starter button. If not, it may be your starter switch.
Old Jan 25, 2007 | 11:17 PM
MCSarge's Avatar
MCSarge
Sounds like a starter soleniod going bad or possibly a dead cell in the battery.
Donn 86 flhtc
Mar 4, 2015 07:42 PM
genokelly
Engine Mechanical Topics
Aug 30, 2014 07:54 PM
pd76
EVO
May 7, 2012 07:22 PM
cvvoord
Dec 7, 2007 01:54 PM
EasyJoe
Jan 25, 2007 12:45 AM
