starter relay click nothing else
Old Feb 22, 2013 | 01:49 PM
chaplaint's Avatar
chaplaint
1st Gear
Default starter relay click nothing else
I have an 03 Dyna low rider. It has been stroked out to a 12-1 ratio. I have an All ***** starter. I had a problem with the starter Jack shaft. I replace it and did a test start with no problems. I replaced the primary cover, filled with oil and now I only get a click from the starter relay. I checked the battery it is fine. I checked the voltage drop and it is fine. So I replaced the relay. Still doing the same thing. Any suggestions?
Old Feb 22, 2013 | 06:25 PM
0lowrider1's Avatar
0lowrider1
There is a sleeve on the inside of outer primary that the jackshaft rides in,sometimes they get a lil worn and causes it to bind ,check that out .first though ..loosen starter bolts and wiggle the starter ,sometimes they get out of alignment ..
Old Mar 8, 2013 | 12:48 PM
chaplaint's Avatar
chaplaint
1st Gear
Thank you all for the help. I tried all the suggestions. All Ana all the problem was grease had built up in the socket in the outer primary cover fir the starter Jack shaft and a bad Jack shaft bushing. Three weeks of no ride. Now it runs great thanks again for all the c help.
DynaRobert82
Dec 2, 2013 05:17 PM
kyfatboy1972
Apr 14, 2012 09:14 AM
Insureguy
EVO
11
Sep 16, 2011 03:47 PM
marc177s
Jun 20, 2011 07:55 AM
02glide
Nov 18, 2006 06:05 PM
