Tuning help
Old Jun 19, 2013 | 09:29 PM
bowhuntenbob's Avatar
bowhuntenbob
Default Tuning help
I have a 2012 Ultra that I am having a hard time getting to run right. I had removed the cat from the stock head pipe, added vance and hines twin slash round slipons and a power commander 5. I have tried a few different maps from the dynojet web site and two from fuel moto with pretty much the same results. The bike pops on decel with some of it being very loud and when I crack the throttle hard the valves rap for a second or two. I am about to give up and put the bike back to stock and just deal with the heat and pinging. CAN SOMEONE PLEASE HELP ME WITH THIS ISSUE..
Old Jun 19, 2013 | 10:04 PM
HD Pilot's Avatar
HD Pilot
I have a Power Vision, so I am not sure if you can tweak things like we can, but for decel pop we will lower the AFR(richen) in the 20 MAP column in the rpm area you are having the problem. Also we will try reducing the Decel Enleanment numbers by 5-10%(richen). Adjusting/ tweaking these areas should smooth out your problems.
Bigkris
VRSC Models
Sep 21, 2017 12:26 PM
aaa1988
Sep 11, 2014 09:09 AM
GuNsLiNgEr420
Sep 5, 2013 03:17 PM
ardbark
May 27, 2008 03:01 PM
grueter
Jul 31, 2007 07:12 AM
