all of a sudden- nothing
Old Jun 27, 2013 | 12:49 PM
adamsthephoneguy's Avatar
adamsthephoneguy
Default all of a sudden- nothing
cruising along and all of a sudden it's like you just turned off the ignition then moments later all power comes back on and pop starts and all is well for a couple miles then does it again. did it 5 times in 10 miles then didn't do it again so far in 30 miles. checked ground wire from batt to starter and seems tight. ignition seems ok.
Old Jun 27, 2013 | 08:27 PM
ultraclassic03's Avatar
ultraclassic03
If your bike is a bagger around 2003, it could be the main circuit breaker. HD had a problem with that set up. I had same problem. Replaced with 50 amp fuse and no more problems. Bike even runs better. Also check ignition switch.
Swamp Tiger
Dec 29, 2015 05:26 AM
WpgGlider
Jul 29, 2012 12:38 PM
bloodyhead
Aug 19, 2008 02:33 PM
thumperhumper
Aug 19, 2008 06:33 AM
madmax1
Oct 7, 2006 09:30 AM
