Ignition Switch Problem
Old Jul 20, 2012 | 02:17 PM
WpgGlider's Avatar
WpgGlider
4th Gear
Default Ignition Switch Problem
I've got an 03 FLTRI with 65,000 miles on it. Has run flawlessly after major professional HP upgrade in 05, (all the best stuff). Two days ago all of a sudden, it stopped on the road, just as if the ignition switch was shut off! No power to anything! Pulled to side of road, flicked switch on and off 1/2 doz. times. After a few minutes, switched it to On again and everything lit up perfectly and it started right off. It ran for 5-10 miles and it died again, just like stated abobe. No Power anywher! Again after a few minutes, the ignition switch game alive and it stared right up and it worked perfectly for another 5-10 miles of riding then it did the same thing. I did make it home eventually, but it did this 6 or 7 times in the 40 miles(60 KM) it took to get home. Has anyone else had a problem like this? What was the solution? I think the Ignition Switch needs to be replaced, what do you think? (tew)
Old Jul 22, 2012 | 07:45 AM
UltraNutZ's Avatar
UltraNutZ
sounds to me like your system relay is going south. when it heats up, it opens and causes loss of all electrical. When it cools down, it closes and allows the flow of electrical power again. if you have a system relay and have never changed it, then change it. it's cheap insurance.
Old Jul 29, 2012 | 12:38 PM
WpgGlider's Avatar
WpgGlider
4th Gear
Thanks, I'll have to check out that relay. That could be the problem all right. I have never changed it. Sounds like good advice. I'll do that.
PoincianaRoadKing
Apr 21, 2020 02:13 PM
gsbuick65
Jul 17, 2018 01:58 PM
dirkpit222
Jul 22, 2014 09:20 AM
WpgGlider
Aug 16, 2012 06:23 AM
ccmdawg
Jun 21, 2007 04:44 PM
