Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I thought about this when I installed mine 2 weeks ago. I used the di-grease, plugged them together then wrapped entirely with black electrical tape, then put inside a sealed plastic bag. Stuffed it all under battery box.
Ride Safe,
Mike
Where is everyone seeing the recommendation to use di-grease? There's nothing in the instructions for my PCIIIUSB that mentions di-grease.
Ride Safe,
Mike
Took your advice, mounted the cables behind the cover and not under the battery box, packed the connector's full of dielectric grease, then placed them in a heavy plastic bag and sealed the bottom around the cables
