perfromance programmers
Old Nov 29, 2013 | 04:02 PM
jibbyvan's Avatar
jibbyvan
Default perfromance programmers
is it worth the money to go from a vance and hines programmer to the zipper
Old Dec 2, 2013 | 09:42 AM
UltraNutZ's Avatar
UltraNutZ
depends on what you're trying to accomplish.
Old Dec 2, 2013 | 10:10 AM
Uncle Chester's Avatar
Uncle Chester
A few more details would help, people can't give an oppinion when they don't know what you got.
Old Dec 3, 2013 | 08:33 AM
Yardstick's Avatar
Yardstick
Zippers is a whole new ECM that will use wide band O2 sensors to tune your bike. There is a lot more control over the running perimeters and you will never need another tuner again. You can change cams, big bore it, change running gears, polish/port heads, etc and the ECM can handle the change. Also, doesn't marry to the bike and can be carried over if you get a different compatible bike. However, the old bike (if changes were significant) would need to be properly tuned before sale.
If you are doing the typical A/C, pipes and maybe a cam…then there are other tuners that will work satisfactorily.
I used the zipper on a 07 SG with just A/C and pipes and after tuning it by riding…..it ran better and more power then using the V/H fuel pack.
TWewers
Jun 29, 2014 08:57 PM
mrace33
General Topics/Tech Tips
May 22, 2014 09:43 AM
huntinbuck2312
Apr 22, 2014 01:23 AM
tlar1540
Jun 11, 2012 10:13 AM
craigffb
Jun 30, 2010 04:01 PM
