Brake light troubleshooting
Old Mar 18, 2007 | 01:13 AM
bigdog_tim's Avatar
bigdog_tim
Stage III
Default Brake light troubleshooting
I have an '01 Ultra. It has been on a battery charger all winter and wanted to take her out for her maiden voyage today. I discovered no brake light. I checked the bulb - burned out - so purchased replacement from the HD dealership. Still no light. Checked the fuse (it is a 15Amp). Fuse looks fine. All other lighting works fine.
Any suggestions on how to troubleshoot?
Thanks,
Old Mar 18, 2007 | 04:23 PM
twowheelsforever's Avatar
twowheelsforever
Default RE: Brake light troubleshooting
Does the tail light work, and just not the brake light? Have you checked your brake switches? If you take the bulb back out, you can use a test light tocheck if it's a problem with the bulb or switch...
Old Mar 18, 2007 | 07:45 PM
bigdog_tim's Avatar
bigdog_tim
Stage III
I haven't checked the switches - will do that this afternoon. Fuse is fine and I have a new bulb. The tour pack lights and light bar all light up - just nothing (not running or brake) on the tail light.
Thanks!
Old Mar 19, 2007 | 12:17 PM
EVOrider's Avatar
EVOrider
The HD module that turns your turn signals into brake lights can burn out. If this item burns out...then you have no brake lights at all. If you have one of these installed...disconnect it.
dan_sandyrichards@sbcglobal.net
Electrical/Lighting/Alarm
Nov 2, 2017 03:27 PM
jackyl
Jul 30, 2016 04:34 PM
AlexB_HDMX
Dec 28, 2014 07:39 PM
RoadHog659
Nov 30, 2014 04:35 PM
Bertha's Boy
Jan 20, 2012 03:06 PM
