Hard Starting Issue
Old Mar 19, 2007 | 07:23 PM
TickTock's Avatar
TickTock
Default Hard Starting Issue
My wife's bike Fuel Injected 03 Heritage Softail is having a problem starting. If the bike sits for a day and I try to crank it, it cycles several times before finally starting. When it finally does start it runs fine and it fires right up with no problem. I let it sit for 6 hours yesterday and it fired up no problem. Waited 24 hours and the same problem experienced yesterday with it cycling through started again.
Anyone have any ideas?
Old Mar 19, 2007 | 09:52 PM
HDsoftail03's Avatar
HDsoftail03
Stage I
Default RE: Hard Starting Issue
Sounds like the fuel lines check value isn't working. Friend had the same problem. Does the fuel pumpstart and shutoffafter it builds pressure andbefore you start it? His had a leak in theclear fuel likne inside the tank that connects at the bottom. He changed the hose and the check valveinside the tank and the problem diasappeared.
Old Mar 20, 2007 | 07:54 AM
TickTock's Avatar
TickTock
I think you might be onto something. It still has warranty on it, so I made an appt with the dealership to inspect. The fuel pump noise sounds strange when it it powers up so I think there is something going on there.
SmokeyJoe101
Sep 1, 2017 11:30 AM
kmc
Nov 26, 2014 08:18 AM
Moboy
Dec 20, 2010 12:07 AM
lowrider1997
Exhaust System Topics
Feb 25, 2010 11:05 AM
hd_sob
Oct 7, 2006 10:52 AM
