First Harley starter problem.
Old Feb 19, 2014 | 07:17 PM
Hoosier bird's Avatar
Hoosier bird
Old Feb 22, 2014 | 12:33 PM
Big>G's Avatar
Big>G
Stage II
Default Jackshaft question
I'm building a custom with a softail primary using a 1994+ starter and am trying to figure out the jackshaft connection.
This is what I've read on here which sounds fine,
"The end of the coupling (the narrow hollow part with splines on the ID) with the counterbore goes toward the jackshaft.
Then the Jackshaft, splined end in first.
Then the large diameter coupling with the snap ring in the center of the ID.
Spring.
Pinion gear. Bolt o ring and tablock."
Everything sounds like what I have, (Spyke Jackshaft) but one part,
"Then the large diameter coupling with the snap ring in the center of the ID." seems to be different. That large diameter coupling has the retaining ring groove off to one end, not in the center. I'm guessing the long end of that coupling would go out to the pinion gear with the spring inside it.
Anyone agree?
Chummers
General Topics/Tech Tips
Aug 26, 2013 12:06 PM
Insureguy
EVO
11
Sep 16, 2011 03:47 PM
mostSilly
EVO
11
Aug 1, 2010 12:46 AM
02glide
Nov 18, 2006 06:05 PM
Joker441
Shovelhead
Feb 8, 2006 04:56 AM
