running rough hesitant.
Old Mar 3, 2014 | 11:25 PM
alliedkiwi's Avatar
alliedkiwi
3rd Gear
Default running rough hesitant.
I've got a 2007 dyna superglide. Have s&s 583 cams, 106 kit, se heavy breather, v&h 2 into 1 comp pipe and pcv.
During running in of bike started to run rougher and rougher. Finally got to dyno tune, found fuel pump not getting to pressure. 30psi instead of 60psi. All replaced and dyned. Seemed to run ok but still hard to start. Now 400kms later its playing up again. Hesitant when running, maxed out at 70mph and couldn't get anymore out of it. Will take back to dealer but thought I'd see if anyone had any ideas. Maybe pcv. Have pc3 I can put back in to try.
Old Mar 3, 2014 | 11:47 PM
wurk_truk's Avatar
wurk_truk
holes in the in tank fuel lines will do this if it runs good when full and shitty when not full.
Old Mar 4, 2014 | 12:10 AM
alliedkiwi's Avatar
alliedkiwi
3rd Gear
Ok wil check. Had done 100kms since fill up.
Old Mar 4, 2014 | 09:09 PM
alliedkiwi's Avatar
alliedkiwi
3rd Gear
Checked out fuel lines but seemed ok. Think I've found issue. There's sand in thebottom of the tank. This may have been what damaged the original fuel pump. Will clean out tank and get fuel pressure checked.
GearHeadedWeerdo
Sep 18, 2015 10:39 PM
toxic
Apr 8, 2015 03:27 PM
jimmything
Dec 9, 2014 07:06 PM
Potato_Potato
Apr 26, 2013 11:51 PM
tmac5854
Exhaust System Topics
May 18, 2007 04:19 PM
