Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
It may be water. Mine would do it on the rear after a wash. Take it off, clean it up and put some dielectic (sp?) grease on it. Clear the code and see what happens...
Thanks TickTock!! It was either a loose o2 eliminator or it was dirty. I removed the eliminator, cleaned it up and applied grease, reinstalled and cleared the trouble code. It seems to have resolved my problem. Thanks again!
Hello,
I have 2006 hdi wg. after stage 1 download ( \\; se II mufflers,se a/c kit, remap ) ecm throw p0134 and p0154 codes which are front and rear o2 sensors.
My question is I do not have o2 eliminators I guess. Is it something you install later ?
And how can I get rid of the codes
thanks for your help
06 wg
hi
shocked !!! dealer told me my bike does not have o2 sensors ? \\; is it true ?? \\; \\; how come dtc shows error codes if the bike does not have o2 sensors ??? I am very confused and need your guidence
06 wg
