After Stage 1..Stalling@ dead stop
Old May 31, 2014 | 08:44 PM
!_gofasterok's Avatar
!_gofasterok
Default After Stage 1..Stalling@ dead stop
Just had my stage one completed by Techno Key..The 103 has awakened and came to life. The only small issue at this point is...When pulling out at a dead stop there seems to be a bit of a miss in detonation and or fuel distribution to the proper area. Thank you in advance for any advice. '12 Electra Glide, Bassani pipes, A/N Air
Old Jun 1, 2014 | 10:02 AM
jmr1971's Avatar
jmr1971
Sounds like it could be a problem with the IAC in your throttle body, but if the company who hooked up your stage I is solid then they should fix this for you.
What tuner are you using?
Old Jun 1, 2014 | 11:42 AM
nevil's Avatar
nevil
So which is it- stalling or a hesitation? If it stalls out then I would first suspect a dirty IAC, which is easy enough to clean using throttle body cleaner spray. It still could be a tuning issue. If you're getting a miss or hesitation it needs to go back to the tuner.
Old Jun 1, 2014 | 07:51 PM
!_gofasterok
Jmr1971 The tuner I used is Techno Key
Old Jun 1, 2014 | 07:55 PM
!_gofasterok
nevil..When @ a dead stop I go to throttle I have to crack throttle to get er going....or there is a bit of hesitation on take off
rs03371
Oct 9, 2014 02:25 PM
Rlpro
Sep 18, 2012 08:47 PM
bezoar
May 5, 2008 08:50 AM
shimmon
Apr 3, 2008 07:45 AM
Dallastx
Mar 11, 2007 10:12 PM
